Not sure of the chain's origin, it's from Pro Mod so I would expect it isn't too bad. I think however I figured out the problem, the Pro Mod engine plate comes with bolts and nuts, the nuts are flanged lock nuts. I think the serrations on the nut aren't sharp enough to cut into the glossy powder coating so they keep slipping, causing the chain to loosen up.
I went to Lowe's with the wife on Saturday to pick up some star washers and ended up with a new refrigerator and dishwasher! We are the 2nd owners of this house the the first owner built it himself, or at least did a lot of it himself. The dishwasher install was a disaster, bare wires in the space behind it, etc. I haven't gotten to the fridge yet but I can already see that the water supply for the ice maker is going to be a problem, no shut off valve! Perhaps I'll get to work on the mini bike by the end of the week....
Here it is with the split sprocket adapter, you can see the chain sagging, that was after a quick pass in the yard and it's already loose!
