hello, i am in the middle of building a modded 212 pred, and was curious on what the torque specs are for modded engines. i read the thread about torque specs but you guys say not to use the same for a modded engine.
so what i need to know is how much ft/lbs torque for the following.
billet flywheel nut-
side cover with studs-
cylinder head with studs-
the bolt that holds down the champ rockers-
and the billet rod is 12.5 ft/lbs with moly lube
if theres anything else that has to be torqued please let me know
thanks.
thanks.
