Hello all! I'm new to this forum. I decided to join after seeing all the awesome ideas you all have.
I have a briggs 3.5 HP flat head vertical shaft engine that I converted to run on propane. It runs great as is, but since propane contains less energy than gas, it doesn't make quite as much HP in the current configuration.
I've already milled the head down, and I noticed a good gain from that.. (With propane, you can run a higher compression with less detonation)
To get more out of it, I know I'll have to at least advance the ignition timing using an offset key or by moving the coil... but how many degrees should it be advanced?
I also heard about how you can grind down the exhaust lifter by about .010 to close the exhaust valve earlier and reduce overlap. Has anyone heard about this? Does it help?
Are there any other modifications you recommend without buying any aftermarket parts besides a flywheel key and maybe a thinner head gasket?
Homer
Homer
