Not exactly sure what is the culprit here.
I recently changed my custom ground cam profile to close the intake at the bottom of the intake stroke where it had previously been closing half way up the compression stroke(ack!) so now I know the reason why I could run on regular, and why I now need to use premium.
I also have a slight leak in my exhaust valve seat which might also be a problem at these higher compression ratios.
I have no idea what would be causing these problems so I'm hoping someone can help me out. Seems to die around 3000 to 4000rpm or so. I'm rather short on money at the moment having just bought a new camera for my job(5DMKII) so I'm looking for some way to fix this and make it ride-able for little to no money. Heck, If anyone can do a cheap valve job for me(if that turns out to be what the problem may be), I'd owe you one.
Anyway, heres a few videos of the engine running. The sputtering while I was accelerating up the road was held at a constant throttle until the sound completely goes out.. It just stopped revving... The engine also dies if I leave the throttle open while this is happening, or when the engine is revving back down if it ever is able to rev higher.
YouTube - gx200 problems.
