Thanks Guys... I got the tire on the rim pretty easily but had a time to get it to catch a bead and inflate...I tried the rope around the tire and tighten it up to squueze the sidewalls out... just wasn't happening so I resorted to the old trick we used on our atv's back when.... brake fluid and a long match :doah:.... not the brighest of ways to do it but it works.... after a few attempts it just lit the side wall up where the mist from the bf sprayed on it... about the third attempt it did the same thing, as I went to blow the flames out I just rested my hand on the outter edge of the tire and POP!!! the tire was on the rim....after changing my BVD's I filled it with air and she is good to go.............
