need a slanted intake manifold for hs50.
C
cyborg
Guest
I bought a hs50 engine but I need a slanted intake for it to work on my minibike. I checked out black widow motor sports and they have them for $35 but I want to be absolutely sure its gonna fit this engine. Here are the numbers from the engine hs50-67197d ser 0227b . The intake on this engine is not a circle so I posted a pic of the gasket to show the shape.
No. It won't work. You need Tecumseh part number 33669. blackwidowmotorsports slant intake is for an hs40 part number 33301
C
cyborg
Guest
Im curious what exactly wont work? I just read it should bolt up but the ID of the intake is smaller. The description on that website says it fits the vintage hs50. I might just have to buy it and see what goes wrong.
It'll bolt up but it doesn't cover the corner of the hs50 intake. I've seen people epoxy the corner so they can use the hs40 intake but you have to use quality fuel resistant epoxy.
C
cyborg
Guest
I wrote a reply earlier but I must have hit the wrong button. Thanks for the info Ajf. I will order that intake and see how it goes. I will make sure to get the right epoxy. Thanks for the help and pics.
