New parts consist of the following: ARC rod and flywheel, flat top piston, rings, wrist pin, F200 .275" cam, valves, springs, retainers, bored SA carb, gaskets, PCV valve kit, top plate, fuel pump, fuel lines, throttle kit, modified rockers. Has new port work and valve job. Glass beaded block, head, and side cover. If you want a stock appearing that will whip on the majority, here it is. NR offers less motor, for around $100 more, plus shipping. Professionally built with awesome technical support. Pull start. It is the black engine with a hex shaped valve cover, and hex shaped pull starter. Pretty cool looking. Well worth the money. Add your favorite exhaust and go. Thanks again for looking.
