Hey Karen , not sure if that will work or not, does the O&R shaft have a keyway
my little engine was 13 mm with no key , so I made a sleeve from 13mm to 3/4 then I used a clutch that had set screws
I test fitted the clutch and marked where the set screws hit then I drilled thru the sleeve and dimple the crank shaft
I then used long set scews in the clutch hub to hold it all together
If you can , find a clutch that has replaceable springs and use the heaviest ones they sell to get the engine rpms higher before it engages , these little 2stokes dont make much torque down low think of a chainsaw they cut best at full throttle lol
:thumbsup:
