In the process of modding up at Predator, just ordered a bunch of parts. Got the motor completely apart, governor out, oil sensor out and flywheel off, head off - all the way down to bare block. Heres the plan:
ARC Billet Rod
ARC Flywheel
BP2 Grind Dyno Cam
18cc Milled Clone Head (going to port/polish myself)
18 lb springs (might have to go 26 lb?)
25mm int, 24mm ex stainless valves
Retainer and Keeper Set w/lash caps
Stock Pushrods
24mm Mikuni Flat Slide carb w/pulse pump
Header Pipe
Deciding on going all out with this motor. Trying to make up my mind on a few things such as a flat top piston, the mentioned 26lb springs and whether or not I have to upgrade the pushrods. What do you guys think on this?
ARC Billet Rod
ARC Flywheel
BP2 Grind Dyno Cam
Stock Pushrods
Header Pipe
