Hi All,
I finally have my PakJak frame and forks all sandblasted and ground down. My question to you is, what primer can I use that is happy with a powder coat process. I do want to protect the bare metal from rust till I powder coat but I don't wish to impede the process and have to remove it all before sending out. Thankfully I do live in Phoenix and currently I do believe that our humidity index is below zero, the moisture is actually sucked out of the air. As of this post, it it a chilly 104 outside.
Also, is there a body putty, bondo type product I can use to fill small scratches in the metal frame?
also, any leads on good powder coaters here in Phoenix, Az,
