Ok cleaned carb got the motor to start with a drill...as the motor idled the starter nut & cup came flying off...i put back on checked my timing put my pushrods & lifters back in..& no start now, i dont remeber if i had a key on my crank...and theres just a little bit of damage to the flywheel nothing crazy.....
Now when i try to start i get nothing just backfires real loud ,spits fire out header
Do you think my flywheel is bad?
Or my valve lash needs to be set again?
