Did as much research as I could and still had a few questions to clear up...
I have a couple of "carts" with products in them and want to make my order within a day or so... those that have upgraded this motor, please feel free to give your opinion or advice...
am i missing anything, or is money best spent elsewhere on anything? just want to do anything i can, without wasting money and without having to machine the block
on the Hemi headed predator:
1- arc billet flywheel 6626 (with 8 degrees timing advance) (ARC)
1- arc billet rod 6254 (but will go +.20 if piston is in the hole) (ARC)
1- 26lb spring set (smallenginecams)
1- isky black mamba cam (smallenginecams)
1- 27mm stainless valve DJ-1127 (is this stock size?) (ARC)
1- 25mm stainless valve DJ-1121 (is this stock size?) (ARC)
2- HD retainer kit, w keepers DJ-1047 (?) (ARC)
2- Chromoly Push Rods (not sure on length ???, same as old style?)
1- port work and mill on stock head (??? youngengines?)
1-aftermarket carb (???), e85 ??? unleaded gas??? ethanol???
or
1- etube 140 and jets (will determine which jet based on test and tune) ???
research has revealed that I cannot use a larger spring than a 26lb, without cutting the pockets? cannot use 1:3 ratio rockers? push rod lengths are different?
am I missing anything, is anything a waste of money for this motor...
or
