Predator 212cc Mini Bike Kit - Stage 1 - Non-Hemi
I found this at OldMiniBikes warehouse. Has anyone bought and installed one before. and is it worth buying. And can u run this kit with the governor installed or do I need to remove it before installing it. Please help
You can run it with the governor. In fact, I recommend it with a stock cam. In my opinion it's the best bang for your buck and really wakes up a Predator. Still easy to start and low maintenance. If you need more info, email me chad@OldMiniBikes.com.
Sent from my Texas Instruments Speak and Spell...[emoji2]
cxbra
New Member
im still using the stock doodlebug rear sprocket. should i upgrade that or keep it
Use the stock rear sprocket. Im a big fan of upgrading slowly so you can see where the changes come from. Do the engine upgrade and test it out.. If you need a different rear sprocket, get it later.
Should be a 12T clutch and 70T sprocket.
