Sorry guys it didn't go good yesterday.
I had a lot of bad luck yesterday at the races.
1st Clutch key sheared on the second clutch lock up, so I ran to my buddy house and made one from a harden steel key.
2nd Got very bad clutch chatter which caused the side cover bolts to come out while I was testing it. Oil everywhere! My buddy had spare bolts there, so fixed that. (but I'm gonna go to studs with flat washer, lock washer, and nylon insert nuts)
3rd The clutch blows apart on lock up,(all clips, and damage disc) so I put it back together and try to ease into it, and it blows again. (3 disc Tomar stellar mod 4,800 stall with RED springs no weights) Need about 5,400 stall with .100" silver springs.
4th the stock motor plate is to weak and the motor was tweaking the frame. Motor looks to be trying to pop a wheelie in the chassis. Gotta go to 1/4" thick steel plate with welded braces around from extra strength.
So I guess next week we will try it again. I will take more pictures for you guys to see the frame mods later.
