I am putting the rear back together , When I install the tension spring on the drum lever the brakes work backwards .Pull lever and the drum releases ,let the lever go and brake locks .Without the tension spring on the drum lever it works fine .Am I missing something .I have tried to fix for hours .1970 Rupp scrambler ,
rear drum brake
Thanks Charlie
rear drum brake
Thanks Charlie
