Well Dave, we looked the Tote Gote over pretty carefully and then made a better machine. The SW is narrower and the engine is mounted more forward and at the time we built these, TG had no suspension at all which made our machine easier to ride. The driver's foot pegs were higher and more inboard that the Gote. This kept your feet from getting hit by stuff along the trail.
The swing arm front suspension is adjustable for travel distance and stiffness. There is a spring steel pressure washer under a stop nut that can add more friction to the spring action. My scooter has a broken spring and they were custom made for the SW. Replacements can't be found. I'll have to have one made. The rear suspension is a single torsion bar with an adjustment wedge at its base. It ran on a diagonal from the frame up toward the rear. The arm on the upper end gave the rear swing arm its spring action. The arm had a tendency to break.
As a demonstration, we made a thing that looked like a ladder made with 2x4s for the sides a rungs. It would lay flat on the ground with the 2x4s on edge spaced about 12 to 18 inches apart. The whole thing was about 10 feet long. We could hit it at full speed and travel its length with hardly a bump. TG guys didn't dare try it with their solid axle scooters.
We made those scooters for 3 or 4 years until the company was purchased by Heston Equipment Co. in Kansas. They bought the equipment and patents for our Sugar Beet Harvesters. They did not get the SW patents or rights. We made 2 models, a 4 HP and a 6HP unit. They both had B&S engines. Production was probably less than 300 units made in 1963 thru 1965. Production ended when the company was sold. The owner always had plans of making more, but that's about time that the Japanese invaded with their scooters.
Alice's scooter looks to be in pretty good shape. Looks like it has a different engine though.
Mine is a 6HP that need restoration, I have the little trailer too. I doubt there are any more in existence.
