WATER SLIDE DECALS
These are just like the old decals we used in the 40`s through the 70`s before everything changed to vinyl stickers. Soak in water for a few minutes and slide on to your tank. Then top coat the whole tank with clear urethane. These are about .004 inch thick so they look like they are painted on after the clear coat is done. These were just made a few weeks ago so they are fresh with no issues. Old stock decals are usually hit & miss if they will work or not as they can get brittle after 40+ years.
All I have is what you see... Made for the Senior Sportsman. The strips where it says "Simplex" and where it says "Sportsman" are clear material, so whatever color your tank is, the strips will also be that color. Same applys to the pin stripe around the "V" it will show the tank color. The gold color is a fine metallic, close to the original decal and made the exact size. The sample photo you see is a quick rattle can paint job on one side only just for display with 1 clear coat after applying the decal to show how the color comes through the background.
Price is $30.00 per set INCLUDING postage to USA
International is $25.00 per set PLUS actual postage to your location.
If interested please send me a message through this site for payment information.
