Try to fix the seat yourself. I didn't know the first thing about fiberglass either and when I got mine the seat had some serious cracks, and a few chunks busted out of it. I took it to NAPA and the guy hooked me up with some resin, fiber matting, etc. Basically everything I needed. It was actually really easy, you just build it up, let it dry, sand, repeat until it's fixed. If you mess up, you can sand it off and try again. I did this all by hand (this was before I had air tools) and it was not only a piece of cake, but it was VERY rewarding. :thumbsup: I'm sure a body shop would have easily charged me over $100, prob. more. As far as the metalflake, that was also not that hard. I used gold flake, and then over 30 coats of clear on the top, then I wetsanded it to a smooth gloss, then I painted a blood red over that, then some more clear and finally sand and polish. In the sunlight it looks like it's a mile deep. :thumbsup: in all it took me about 3-4 weeks to do the seat, but it was only about a half hour day. Most of the time was letting the clear dry.
As far as the diff goes, if you put a solid axle in it, your right- you won't be able to turn. You can find these diffs in older (70s) John Deere snowblowers, as well as on other yard equipment.
Yes Steven I agree, I also like to keep the torque closer to the support, it seems to flex or bend the shaft the other way.
