Combination of boot resistor, resistor spark plug and high flux density flywheel magnets seems to be causing some premature coil failure.
I am going to stick to my guns on that until proven one way or the other.
RF noise has not been an issue to this point, I can barely hear the radio at all.....
I can totally agree. The resistor spark plug itself is for suppressing noise, however it also lengthens the dwell time, which is good for high RPM.
If you use a resistor boot and plug that is too much and will reek havic on your coil.
Done properly you can run a resister plug with a solid wire, and nonresistor boot. However you will be limited to the resistor in the plug, which is not very optimal at all, but will work better.
As I understand it: the best setup is to run a specific resistance boot to whatever RPM you want to run your engine, with a nonresistor plug. For this too be optimal you will need to go to a solid core wire, as resistor type wires will add resistance as well.
To much resistance will rob amps. To find the perfect balance is key..
Go a little bit outside the box here: platinum plugs and iridium plugs have more resistance than copper plugs= some food for thought.
Look into champion copper truck plug.
Platinum and iridium are a waste of money.
