This kit has a 1.25 lb nitrous oxide bottle, solenoid, small/medium/large nozzles for spraying into the air snorkels on a fuelie (the old way to say fuel injection) bike, plumbing, and an arming switch.
Add a small 12 Volt battery (4 Amp hour alarm backup battery), 5 Amp fuse, fuse holder, momentary-On "spray" switch, and you have a nitrous system for your mini.
Jet the carb richer than normal, run a range or two colder spark plug than normal, and go. Make sure its clutched in and pulling at low RPM then spray it. Spray as it pulls up through the gear, but let up on the spray before reaching top revs... it needs a few strokes to clean the last of the spray out before it will start throttling down.
Nitrous Oxide adds 3 molecules of Oxygen and one of Nitrogen. Dry Nitrous is a gas which expands violently as it flows out the nozzle. When a gas expands it gets
cold, so all air entering the engine is cooler and more oxygen-laden, and thus more dense. With so much more Oxygen going in, you must add fuel... or else you will melt aluminum. Fatten it up before you spray.
Jon
