B bigmike211 New Member Aug 31, 2015 #1 Aug 31, 2015 #1 do i have to use 8 advace key or can ii just use stock one
OND Aug 31, 2015 #2 Aug 31, 2015 #2 Hey bigmike, you don't have to use the 8 degree advance key if you don't want to, but it would probably gain you a little more ump.
B bigmike211 New Member Aug 31, 2015 #3 Aug 31, 2015 #3 OND said: Hey bigmike, you don't have to use the 8 degree advance key if you don't want to, but it would probably gain you a little more ump. Click to expand... is hard or easy to install?
OND Aug 31, 2015 #4 Aug 31, 2015 #4 Just need to pull the flywheel off ..Install the key and reinstall the flywheel.
