stuck check valve in tecumseh carb
oldfatguy
I went out and started all the mini bikes to get them ready for some riding time over the holiday. I found that my one h60 wouldn't idle even after cleaning the jet so that meant only one thing ---stuck check ball. I shook the carb and sure enough no rattle. I soaked it over night in gas, sprayed it with carb cleaner. I even sprayed wd40 into the hole the idle mixture screw goes in. Then as a last resort I gave it a few good taps with a plastic hammer and that did the trick and freed up that check ball. I was so happy to hear that rattle as I shook the carb. I put it back on and it's running great again. Just thought that I would pass this along as it might help you save one of your carbs. I did buy a brand new Steens tecumseh carb on e-bay and for some reason it doesn't work I just can't seem to get the engine to run right with it.
MB165
Glad you got it running, it doesnt take much for those to stick. Todays gasoline is crummy stuff, I have had good luck boiling them to loosen them up.
oldfatguy
I heard that boiling them in vinegar helps . I have a few that seem hopeless even after soaking for months in carb cleaner. I'm going to give the boiling a try.
