Cleaning out some stuff, all this stuff is from H series period correct year engines.
Crankshaft, 1971 H50 ball bearing supported, 3/4" tapped shaft $30
camshaft 1971 H50 with lifters $30
ball bearing supported sidecovers $10 each (2)
heads $5 each (3)
1969 HH40 stamped plate engine shroud/backplate/fin-head tins (get rid of the "hump") $25
steel flywheel, non lighted no broken fins and good bore $10
various head and fin tins, govenor "U" linkages $3 each
carb adapters $6 each (2)
Flywheel cups/screens $7 each
mount plates $4 (2)
Prices do not include shipping, shipping will pretty much be actual through usps, most likely $3-15 depending on size weight and will combine to save money.
Block was corroded in the cylinder on the engine that the cam/crank came from, bottom end was spotless-and it WAS from a minibike!!
heads $5 each (3)
mount plates $4 (2)
