The engine stalls when giving it more throttle. The new points were gapped at .020 on the high side of the cam and cleaned before starting, the piston was set at .035 btdc with a dial indicator, a electronic meter set on ohms was used while moving the stator plate to see the break in continuity at the points and the bolts tightened, and 2 carburetors adjusted 1 1/2 turns on the main and 1 turn on the idle air screws ( tried one older and one new carbs). The engine starts easily and idles but when turning the throttle it stalls. Did I miss anything that should have been done to this engine ? Sorry if this question has been asked before in the forums . Any help would be appreciated. Thanks
