You are welcome Clay :thumbsup:
Congrats on your acceptance to school, I'm very happy for you!
Onward....
The end is near :blink:..... Thank God!!!!!
I now have electrical contacts..... The cables now hook up to something other than air :shrug: I still don't have the rear brake hooked up though. Besides......Who needs a brake any ways :shrug:.... I'll just down shift to slow down :helpsmilie:
I hit up McMaster & Carr once again for these weather tight connectors.....
I started on the engine's wiring harness first and worked my way towards the wiring harness on the frame. (with the engine all the way to the back of the mount) After I got done installing the nylon sheath all over the place, and melting the Raychem tubing in place......
I installed the pin and sockets of the weather tight connectors to the wires, then I crimped them a tad and then soldered them to the wires, for a positive connection ....
All done with the engine's wiring harness..... Ready to go.....
I could spend a lot of band width here on the art of wiring :doah: to make it simple, I always leave a loop (slack) of the wire before it enters the connector. I also make sure that the connector(s) are supported by the wire once in place. I.E meaning..... That I cut my wire(s) to a length that will support the connector once installed without any others means of support. Then I install clamps as needed to support the harness.....
Are these type of connectors really needed :shrug: you bet they are! In my eyes, they offer a positive connection and will not come loose due to vibration, they can be taken apart and put back together again and again. Besides, I just never know .... I just might get caught out in the rain on this thing :shrug:.....
BC1500 DAVE .... Mixing up some GAS :nuke:
