i did some more up grades to my thunderbolt over the summer and WOW what a big improvement.
first thing i wanted to do was install a 7inch driven so i could help gear the bike down some more and take more advantage of the cam/motor. way the bike was setup it was not taking full potential of the motor. gearing was holding the rpm's back.
here was the Big trick that i had to do. make the factory comet torque converter cover look stock over a 7 inch driven.
first i had to split open the cover to clear the 7inch and then adjust the metal mounting tabs. also use a small metal plate in front of the cover that i drilled into and also through the plastic cover to hold it in the correct position so i could fiberglass in the small voids.
came back and clean up the cover little and now it looks stock again......:thumbsup:
also took a blank aluminum 72 tooth #40 chain sprocket and bored a center hole, bolt pattern and also lighten it up by boring multiple holes.
you can see the different sprockets i had on the bike. first sprocket was a 54tt the second was 58tt and the custom 72tt
after i installed the 7inch and the 72tt sprocket i did notes a difference,but i was still experiencing a small lag when i was going into a corning and trying to accelerate. at that point i new i needed to make the motor rev better and not have the driver lockup. i install a set of white 3100 stall springs. Now the bike just rips out of the corners.
i did start to experience a small problem when the torque converter warms up. i seems like the unit likes to stick little and trys to pull the bike at idle. for some reason one of the springs looks to be damage. might be the problem. i really don't like the comet unit for high performance use. it still works good with the cast iron flywheel and i don't get any unwanted vibrations. cast iron does a good job observing any unwanted vibrations.
one other thing i did to the bike was move the carb behind the block. no reason really , just did it. i had the intake made for my drag bike and now that engine is all apart. so i threw it on...
