The 610 is a lower geared version of the model 600, making it even harder to push when not running. If you need to roll it, use a stick or something to pry open the driven clutch then put a short stick in to hold it open. Use a short stick so the pulley can still turn without hitting the stick. A member on here had decals, I think his name was 'got gotes'. You should post this in the general talk area since the tote gote wheels are larger than 6".
