The main problem with turbo'ing a small engine is, how much boost can that engine take before it blows? If the engine can only take 25hp before blowing up, you might as well stick to an all out motor normally-asperated build. It will perform better, look better and sound cooool. If you did turbo an engine, turbo something big enough to make some REAL hp and that has the capability to handle more abuse.. I'd say a GX390 with billet rod, flywheel, blow-thru carb would work well for turbocharging. It would have more displacement to spool the turbo as well as the ability to get you possibly in the 30hp range without hurting the engine too much. Turbo a gx200 and im sure its going to be under a lot of stress in the 20hp range. Im speaking COMPLETELY off theory though.
