Thanks so much Vette,
Thats exactly how I envisioned it,how you have it pictured.The problem we are having is with the black plastic piece.The metal end of the conduit goes into the larger end of the black piece(In your last pic).But the other end of the black piece on ours is a tiny pin hole maybe just large enough for a naked cable to pass thru.There is no way I can see to feed anything thru that pinhole.How did you pass the barrel thru the black piece? Unless we were sent the wrong black piece? In the 3rd pic down I see you have the cable with barrel end going into the metal throttle housing,then the black piece,then the conduit.How in sam hill did you get the black piece on the cable like that,past the barrel? Maybe I can borrow a camera cause this is indeed a mystery.Thanks again!
