Late entry with my zebra but I plan on starting on it after the taco is finished. As of right now the plan is to use taco 22 forks, a built hemi predator, old school raised edge tri-stars, and a bright color that I'm still undecided on.
Frame is rough. Someone added foward pegs and the clutch side original foot peg is completely missing which left a huge hole. I plan on replacing the missing pegs and undecided on leaving or removing the added pegs. Foward pegs might be nice when taking tight turns but we will see. Rafa at Gt's Hobbies copied the taco 22 forks and I plan using them with the build then I will call the bike "The Zebra Taco" haha
Motor I have in the picture is a hemi predator I slapped a Honda tank and cover on since I bought motor with them missing. The plan is pretty basic build with a +20 rod, flywheel, non-hemi head I already have (head has 26lb springs, stainless std size valves, and roller tip rockers), and most likely a decent size cam. Still unsure on what carb to run.
Excited to start on this one. Should be fun with the built up predator and small tires!
