i use a 22mm mikuni on my pred, and yes you have to get a intake adaptor/manifold . and youll wanna put studs on the block .only problem ive had with my mikuni is the float sticking , use a fuel shutoff valve , cause your piston and rings will fail if your engine doesnt explode 1st from the gas in the crankcase.
