Hi,
I have a shucks baja mini, with a 5.5 jiang dong clone,
that won't start after removing the governor.
It would start on the first pull before I took out the gov.
Can't figure out what I did wrong..
I took off the governor gear & flipper linkage.
plugged the holes with 1/4-20 plugs,
The cam fell out, and I put it back in,
I lined up the dots on the crank & cam, with the piston at TDC,
as far as I could tell it was all right.. but still no luck.
(I tried re-doing this step several times, because I thought it might have been 180 out, & still nothing)
I do have spark.
I should have fuel,.. but i'm not sure.
I tried putting in my #90 jet & spraying cleaner through the carb.
but maybe it's clogged up still, I dunno..
:censure: getting frustrated..
I just got an intake, jet & valve springs for it, & now it won't run. :thumbdown:
Any suggestions on what I should try?, to get it started..
I do have spark.
