Yamaha BW-80
Hi all,
I just got this bike from a guy at work. Its kind of a basket case. At least it was free...now I have a summer project, not that I needed another.
No spark..If anyone has any ideas on where would be the first place to check I'd be grateful. I did switch the spark plug.
Its also missing many parts that I will have to track down. and I have to do a bit of welding on the foot peg mount.
Thanks! 20230612_205218.jpg 20230612_205231.jpg 20230612_165623.jpg 20230612_170108.jpg 20230612_165639.jpg
If it were mine, I would look for a wire from the coil going under that flywheel. If there is a wire there, I would remove the flywheel and look for a set of points I could clean and adjust.
There’s another problem. the screws for the flywheel are totally stripped. I’m going to try to weld a bit of steel to them. To extract them, then just replace them. Otherwise I will get a lefty drill bit
Did you try removing that nut in the center? The one that holds the flywheel on the crankshaft? Those screws took like they might be holding the points mounting plate to the crank case.
Yeah I been looking for parts. my shopping list so far:
Exhaust pipe, shift lever, air box, left side engine cover, probably a gasket set, and maybe piston rings (guy who gave it to me said it smoked a lot)
It's 2 stroke, correct? Rings would make it really weak and hard to start, but not really smoky. If it is 2 stroke, the oil is mixed with the gas. If the mix ratio is not right, you may get smoke. If the gas/oil mix gets old, same result....smoke.
Yamaha dealer MIGHT have some of those parts.
#19
ok, thanks. How might I go about testing the oil system? I'd like to check that over. there are actually 2 oil reservoirs. one in the motor itself, ig for the crankcase, and one under the seat, oil that gets burned. I'll probably drain that.
Is there a way to adjust how much oil its getting? I suppose that could be the smoke problem.
I did start it for a second last night.
Triley41395
I'm going to throw in my 2 cents worth. I'd just do away with any oil injection system and mix it myself. Leave all the parts for the look. Alot of these older engines are getting harder to find parts for and it only takes one time for an oil injection to stop and you can be fried. Our old boat engine has a good injection system but it's unhooked and we just mix it up.
