Hi I just removed my governor on my 212 with the basic stage 1 upgrade kit. I removed the low oil sensor, got the washer behind the governor, lined the dots on the cam up, did all the wiring correctly and checked the plug. The motor would not start so I took off the OHV cover and the engine cover to get to the cam. It turned out that the 2 things next to the cam were not aligned both the push rod. Im not good at explaining this but I put it back the way it should be and aligned the push rods on the 2 arms under the OHV. then it worked fine and fired up. Today I went to start it and it sounded normal but after a few pulls it did not make the normal noise out of the exhaust when I usually pull it. It feels like it has lower compression and backfires every now and then with huge flame. The backfire is not loud either. It was doing all of these things the first time when I didn't put the motor back together correctly. I don't know what to do. I will just put the push rods and things at the end of the push rods by the cam back together but im afraid it will just make this mistake again and "pop out of place". how can I fix this? Also I have not ridden it after the governor removal because I am waiting on a clutch.
