i got about 5 of these wisconsin robin 5 horse motors with these carbs here.
can anyone tell me if these would work on any other higher performance applications>>?
note the quarter next to the ports for size.
theres a set of 2 honda carbs as well,unknown what they came off of or fit?
thanks...
I have no idea what these rim spacers work on.
Diameter is 5 3/4". 1" wide.
Bolt holes center to center across the piece is 4 3/8".
(3 1/8" in a circle)
Possibly Lil" Indian or Ruttman ?
I hope someone here has seen these before.
Will this sprocket/drum combo from OldMiniBikes warehouse fit on a Rupp turbine rim?
Here's the link to it #35 60T 4-1/2" Sprocket Drum for Internal Brake - AZUSA 2217-ID
If that one won't work, could someone direct me to one that will? Thanks!
hi guys I got a line on a good older 5.5 briggs cheap,was wondering if it will work.has anyone tried to fit one on a doodle bug.the height of the engine itself will be fine,just wondering if the plug will get in the way of the frame?
Looking to build a pit bike type deal. Don't know if this is classified as a mini bike but I bet you guys can help
What engine from 110 to 125cc would be a good fit in this polo I frame?
I'm currently restoring a 1970 Fox Sundowner, and want to buy a 212cc Predator to put on it. However I have doubts about the engine fitting. The dimensions of the Predator are as follows:
Height: 13-3/5 in
Width: 12-3/5
Length: 15-2/5 in
I measured the frame roughly where the engine would...
Went to put my #6620 ARC Flywheel (OldMiniBikes bought of course) on my Flattie last night and it doesn't clear/fit over the points cover or the mounting bosses with the points cover removed. Didn't see anything here or any web search where anyone has had this problem. I can't be the only one putting...
Picked this up and wondering what engines it will fit that have a 5/8 shaft from the 60's? Was 5/8 more common back then than 3/4?
I have the driven for it too.
Will this throttle set up work for my 1988 Briggs 5 horsepower.
Is it easy to set up?
http://cgi.ebay.com/ebaymotors/Briggs-Throttle-Kit-Go-Kart-Bar-Stool-Racing-_W0QQcmdZViewItemQQhashZitem1c179eabcaQQitemZ120655358922QQptZRaceQ5fCarQ5fParts#ht_500wt_956
Hello Fellow Minibike Addicts,
I got some of these really badass clutches but the size is just a tiny bit over 3/4". Is there a cheap way I could make it fit? Spacer or something?
The engine shaft is .75", and these clutches seem to be .788".
I have many of the center...
i went to the yamaha dealer the other day because i needed some new levers on my bike. the shop guy looked through shop manuals and assured me that these would fit my bike. so i paid 30 buck for them. i get home, put the clutch lever on. everything is fine with that. but then when i go and take...
So i am need of an upgrade and i saw on ebay a .020 overbore flat top piston and rings set for $25.00. Would i be able to fit this bad boy in with cylinder without having to bore it?
Also can i use a gx140 flywheel on my gx200 clone?
EDIT: i just double...
I am looking for a header for my gx160. I saw this one in another post but the website says its for the GX200. Will it fit the Gx160?
DJ-1138
I also saw the one from Gecker but i think this one goes more straight back
Has anyone bought one of these? How did it work? I need the...
