ohh60
  1. deezildennis
    Jacked up Tecumseh ohh60 (Governor removal gone bad) Need help
    One of my Buddies bought a new tecumseh 6.0 powersports engine a while back and decided he didn't like the governor after he broke it in. The engine ran perfect before but not so much afterwards. I brought it home to keep it from going in the scrap pile. It literally has like 5 hours on the...
  2. Sprocket86
    OHH60 carb swap
    Has anyone swapped out the primer bulb, non adjustable OEM carb that comes on the Tec overhead powersports with an older dual adjustable needle Tec carb?
  3. C
    OHH60 Idle/Governor Help
    Hi all, Trying to get this running correctly for a kart project. Was not running when I inherited it. Motor was caked with cement... I bought new carburetor, I'm guessing it's a Chinese knockoff. Got it all back together, she starts up however it races uncontrollably. I have...
  4. Bignate123
    Ohh60 performance air filter
    Where can you get a performance air filter for a Tecumseh ohh60
  5. J
    Upgrade Advice for Tecumseh OHV 6.0 OHH60 Carb, Plug, etc.
    Hey all!! I have a Tecumseh OHH60 motor and want to do a few simple mods/upgrades. The carb on the motor now is stock, I found a high performance carb on ebay (New High Power Racing Carburetor Tecumseh 640346 640305 Fit OHH50 55 60 65 | eBay) but the carb does not have a primer bulb, but does...
  6. K
    Looking for a tecumseh ohh60 cam
    Does anyone know if this cam will fit the tecumseh ohh60 New Tecumseh Dyno Cams Camshaft 255 OHV 5 5 HP Race Kart Parts | eBay Also if it does how much different is it from factory? I have a robertson's torque tube, an adjustable hs50 carb, and a cone filter. If I can find all the...
  7. K
    Tecumseh ohh60 header
    Has anyone used a robertson's torque tube on a Tecumseh ohh60? I'm just wondering how it sounds and if you noticed any performance gains out of it.
  8. K
    Tecumseh ohh60
    I have an old Tecumseh ohh60 that is on a mini bike and has not been ran in a long time. I drained the oil put in fresh put gas in it and fired right up. Kinda seemed like it was bogging and surging but ran good sometimes. Shut it off and the entire tank of gas ended up on the ground since...
  9. J
    Air Filter Change on Tecumseh OHH60
    I put on this aftermarket air filter. Is there anything else I need to do, to tweak or change a setting anywhere because I put this on? It looks cool, but I don't want to wreck an otherwise perfectly performing engine. Thanks!
  10. Rollin310z
    how can i upgrade tecumseh ohh60
    i have a 6hp tecumseh power sport, what kinds of mods or parts can and should i get to make it better, like springs rods airfilter gas govner or remove it, new carb also will a 5hp head on a 6hp do any good, and where can i get these parts all i run into are parts for honda or predator
  11. Docdc
    OHH60 vs. OH195
    Can anyone tell me the difference and if one is better than the other. Is there a reason not to buy either. I have an option to buy either and I am a little lost between the two. Thanks so much.
  12. J
    OHH60 - looking for billet rod
    I tried looking for a billet rod for my OHH60 and came up with something from ARC but it was for the HS50. The tech said that a lot of the parts are the same which the length was so I got it. BUT, there is no end cap on it so I have no way of installing it without splitting the crank somehow...
  13. M
    looking for OHH60 governor springs
    I just picked up a Tecumseh OHH60 engine, and need the governor springs and the linkage from the governor to the carb. I found the springs on EBay for a few bucks, but still need to find the linkage piece- so I would like to find it all together to save on shipping. Email to...
  14. MisterRoboto
    ohh60 coil
    i have an ohh60 that when i got it it was taken apart and im wondering if anyone could point me to or knows where the 3 different wires(aside from the plug wire) that come from the coil are supposed to connect thanks guys:thumbsup:
  15. prominentalex
    Tecumseh OHH60 Compatibility.
    I was wondering what engine parts are compatible with the PowerSport 6HP OHH60. I head the steel cam from the HS50 fits, I'm currently looking for one. What can I do for air filters and valve springs for higher RPM? Will this OldMiniBikes.com - Replacement Mini Bike, Go-Kart & Small...
  16. creia
    Tecumseh OHH60 - Governor setting
    As you can tell by my previous questions/posts I am new to these engines, and learning alot from the collective knowledge on this forum.:001_tongue: This is on a 2 year old 6HP engine: I have NO intention on removing the governor, however I do want to make sure it has the PROPER...
  17. creia
    Clutch removal on a Tecumseh OHH60 6 HP
    After a 40 year hiatus from mini-bikes I am enjoying them once again as my son has caught the "fever" and picked up his first bike last weekend. (Yes, I am an "older" dad) I went to pull the clutch for inspection and noticed that there is a bolt and washer on the end of the drives shaft holding...
  18. 125ccCrazy
    I need a C-clip for an hs50,ohh50, ohh60 piston
    I was gathering the parts together to reassemble my HS50 and somewhere I misplaced one of my Circlips for the piston, all the others I have from various brands of engines are too big or too small so Tec must have thier own special size... If anyone has one of these clips let me know what you...
  19. 125ccCrazy
    I need a steel cam for an HS50 or OHH60
    If anyone has a cam to fit these engines (same cam) let me know what ya need for it... I found an h50 cam on ebay but I ran the numbers and they didn't match an HS50, does anyone know if they interchange, maybe Tec changed part numbers like they were known to do??
  20. 125ccCrazy
    bearing side cover for Tec ohh60 / cam
    looking for a bearing side cover to fit a Tecumseh OHH60... Also like to find a performance cam, rod or other performance parts.. The cam and rod from an hs50 will also fit if that helps..
