Mark
Got the stickers from Don. Really nice and easy to apply. Bought a roll of white 'striping tape' to border the edges of the side panels. Now, even with its decals, it looks, to my jaundiced eye, to be too Plan Jane. Not sure if a 46 had that, as did later models, but it's gowna be applied anyway. I believe all the Supers had the stripes. The stuff I bought is 5/16" wide.
Is it true that your model had the sediment bowl attached to the tank? Mine, I was told by Don, goes on the carb.
The attached pic shows how much I cut off the top of the 90 degree filter adapter to make my air cleaner clear the side panel to eliminate the interference between the air cleaner and the side panel. Under the adapter it shows a spacer on the bolt, of approx. the same length as the piece removed, so that the original bolt would not have to be shortened. I attribute the interference, on my machine, to the fact I am using the wrong engine...but I've been wrong plenty of times. Could be the wrong adapter or the wrong air filter. Or, for that matter...the wrong length intake manifold! It's my experience that putting rubber or plastic under the engine does not change the vibration characteristics. So, I'm thinking, that removing them would mean that you will need to cut less off the elbow, or whatever. As the engine base has little [lateral] slots I moved my engine as far as possible to the left. That helped a little. Also very slightly tilted the elbow so the top of the air cleaner is a bit closer to the left. I suppose it would have been OK, on this non-restoration, to make a spacer that would be inserted between the manifold and the carb. to lower it, say, 3/8". But I didn't; resorted to the lesser evil, as I saw it at the time, of cutting approx. 3/8" off the discharge end of the elbow. Figured it was best to do other things, anything, than chop the air cleaner!
Bought a muffler from Don but can't use it because of the non-stock battery box that was necessary to mount behind the engine. I'm going to get some flex pipe and route the exhaust out the back...somehow.
Regarding the throttle cable. I bought a new one. Don makes them! After comparing it to the original I can attest it's a perfect reproduction in every way.
