Unfortunately the original carb on my 1972 DMP Scamper with the TEC H35 engine is shot. Someone over tightened the LS needle and broke off the metering tip of the needle in the carb body :censure:
I hear no check ball rattle when I shake the carb body and the throttle shaft has a good amount of slop. Time for a replacement carburetor.
I attempted to mount my O.E.M Tec HS50 carb that I know is a good running carb but this little H35 didn't seem to like it.
I cannot get it to idle with the choke off. LS needle is at 1 turn and HS needle is at 1.25 turns out. It almost seems like it's running out of fuel in the carb bowl.
Will these smaller HP engines run with a larger HP carb mounted to them? Both carbs have the same throttle bore but the HS50 carb does have a larger venturi.
How critical is it to run the fuel line through the fan shroud behind the flywheel for proper gravity feed fuel flow?
Here is a pic of the engine I'm referring to.
