The way my motor is mounted on my gokart, the drive shaft is too short so that it doesn't line up with the axle. The type of axle i have is one that the wheel rotates around it, so a sprocket must be mouted to the 1 wheel and a chain to connect wheel and clutch. My clutch and sprocket won't line up properly.
Is their a driveshaft extension that I can put on and than mount the clutch On that?
If not.. I plan to cut the old axle out completely and swap it with a love axle.. So both wheels are connected by the spinning axle and both wheels are driven. So the sprocket would be mounted on the axle.
Is their a live axle type kit or something i can order?
