Hi everyone,
This will be the build log for my 2x2 project.
I love tinkering and have completed a few big projects in the past including a 4x4 buggy, but this will be my first 2 wheeled project. In fact I have only ridden a mini bike once and crashed almost immediately...... but I'll figure it out.
On to the tech.
Here is what I have so far:
1984 Honda atc125m for the engine/trans
25x13-9 Duro hf243 4 ply tires on 9x9 wheels
1000 lb capacity trailer hubs/spindles
6" Airheart discs and mechanical calipers
Tractor PTO overrunning coupler
1" keyed U-joint
Buttload of sprockets, bearings, chain, and keyed shafting
The Plan:
I will fabricate the frame from scratch, and there will be no suspension, only tire flex and a sprung seat. The forks and rear "arm" will be single sided. Inboard brakes. And of course a winch and snorkle. This thing is being built extra heavy duty for extreme abuse.... 1" shafting and #50 chain!
Pics:
Good running donor. Electric start 4 speed with hi/low range.
Wrinkly tires.....had to use the lighter fluid bead setting technique.
25x13-9 compared to 22x11-8 from the three wheeler.
Tractor pto overrunning coupler to allow the front wheel to go faster than the rear in a turn. I plan on cutting it down and welding on a sprocket.
On to the tech.
1" keyed U-joint
The Plan:
Pics:
