I just went through the same thing with my Arco. The scrub brake would not allow a bigger tire. I didnt want to make it any faster. I have the PMR Jackshaft on the HF 79CC engine.
I ended up getting a 60 tooth sprocket and the Jackshaft sprocket to keep the final drive the same. I did have to reweld the scrub brake to make the bracket higher sos not to hit the chain.
Worked well.
If you have a bigger engine and a decent clutch, you can go to a 60 tooth no problem. I have a Fox with a Pred 212 and a 60 Tooth on a cheapo clutch and it pulls fine.
