I have a few questions regarding connecting throttle cable.
There appears to be two locations where cable can be connected.
One is at the side of motor and moves up/down vertically.
Or it looks like it can be connected on the bottom part horizontally
Which location should be used?
right side or lower bottom.
2nd question.
Should the tension on main heavy spring(upper left) be set where the governor spring loop is just touching?
This is the point where throttle on carb starts opening
In this picture I'm holding main spring down with fingers.
2nd question.
