Actic Cat Climber
I have a 71 or 72 Climber. It is the frame; front forks and handlebars; front tire; swing arm and shocks. Previous owner welded nuts on the swing arm to hold a rear whell axle. They can easily be removed. That owner also welded the jack shaft straps. They too can be removed. The jack shaft and chain will need replacing. Doing a bit more cleanup on it and then will post pics. All in all, pretty good shape and ready for restoration.
Location is Bloominton, Minnesota
