has any one ever tried advancing the cam shaft one tooth ? I'm working on mildly built briggs and stock the valves open and close at TDC "top dead center which means the piston is at the very top of the stroke " .
By advancing the cam one tooth the intake valve starts to open just before TDC and is fully open as the piston moves down.This also lets the exhaust valve start to open just before BDC. I was thinking that opening the intake valve sooner would allow more fuel to be drawn in and opening the exhaust valve at the bottom of the power stroke will use part of the fuel burn to force exhaust out of the engine this should improve the air flow through the engine .Has any one else experimented with this ? I also realised that the Easy Spin feature was opening the valves at the beginning of the compression stroke,a little grinding and filing of the cam fixed that
