After having my frame so quickly ID'd by Simple Tom and the Restore Kid,I have decided to build my first custom mini around it. 1st step was to strip off the cruddy paint it had been bathed in at some point in the last 40 years. Just a little light rust and a bit of corrosion where I assume the gas tank would rest was a comforting sight.
then,correct some of the sour owl s#!+ welds at the down tube/motor mount.
broke out the torch and laid down a few beads to build up the area and then smoothed it all out with the grinder.
tomorrow,I'll weld in a reinforcing sleeve over the joint,and then,on to a new tubular extended swing arm..
