Bonanza Jack shaft swing arm pivot clearance from chain
On my right side, Jack shaft 13 tooth Jack shaft sprocket to a stock Bonanza rear wheel sprocket my chain is sitting on the center swing arm pivot. I have the correct shocks on 10 1/2 inches to me. It looks like my jack sprocket needs to be bigger and he thoughts on this,for more chain clearance IMG_9503.jpeg IMG_9504.jpeg IMG_9504.jpeg
I’ve always used 15 tooth sprocket on the jack shaft to the rear wheel and a 13 tooth sprocket on the jack shaft going to the clutch.
So I took it for a run up the street. It’s kind of quick it tops out at 22 miles an hour. it’s the slowest out of my four that I have.
#19
But your clearance is better than mine by an 1/4 in I think. I have some need a little more.
I also need a little bit more top speed and power lol.
