You guys are both right. However I must not have the right brake on the back of mine or perhaps the sprocket is designed with an offset so the brake drum fits inside of it. Here is what mine looks like.
I am keeping it as stock as possible but I do have a budget. I am going to go with an 11 tooth clutch and a 72 tooth sprocket. The warlord approved $500. The frame with a few spare parts was $125, That Honda was $75. So far my list of parts through my contact, OldMiniBikes and eBay is over $300 and that doesn't include a primary clutch, secondary clutch, jackshaft, bearing retainers, bearings, and sprockets... There's no way I could fit that in as cool as it would be to have that set up. Plus, the crank shaft is 5/8" so finding a primary with that diameter was not easy when I was looking. Also, as much as I wanted to get the Rupp Trails I had to settle for the Cheng Shen Trails...
Anyway, I have many parts on order. Should be running in the next couple of weeks.
