Hey guys, need some extra space and pocket change to fuel my v8 s10 swap.
'73 mildly modified briggs 5hp (Orange) kool bore, Shaved eyebrows/cleaned up ports/ solid gear crank, COMP GP9330 cam, Stock length ARC billet rod, billet lifters, ARC billet flywheel with +30 degree timing, Bored .10 over. After multiple failed attempts at pull starting the starter clutch casing cracked and that's how it sits. Engine has only about an hour of run time on it. needs a flywheel nut, header, carb and a bike. 3/4 x 2-1/4 drilled and tapped crank. Asking $170 (note: engine has been sitting over two years)
'79 Briggs 5hp (White) kool bore, Got this engine as a spare, threw out the tank, carb, and muffler. Underneath the head looks great, cylinder looks like it had a fresh hone and the intake, head, and exhaust gaskets look fairly new. wouldn't take much to get her up and running. 3/4 x 1-1/4 drilled and tapped crank $60 (note: I have never ran this engine, but everything looks good and shouldn't need much to get going)
late model I/C 5hp briggs steel sleeve engine. Ran a few years ago. I never dug into this one because it was a friend's motor, been sitting on a shelf ever since I bought it back. believe it to be a dual bearing but im not 100% sure. I'll have to pull the serial # off of it. 3/4 x 2-1/4 drilled and tapped crank. $100 (note: ill get a picture in the next few days. its sitting in a bike at the moment.)
All motors are "AS IS" and come without exhaust or carb/intakes. White one is missing its magneto in the picture but I will put it back on before shipping. Motors will be shipped drained and securely.
Also have all kinds of miscellaneous parts for these engines. haven't had a chance to dig yet but just ask and ill let you know.
All prices are OBO + shipping from 33981. If you're interested, shoot me a pm and we can work out a deal. perferred method of payment is Paypal gift, but we can do money order if necessary.
thanks for looking guys.
