According to the dictionary caper is defined as: n., silly action or prank. vi., to leap in a playful manner; frolic.
Ben Hunt, here in Walla Walla WA, made pick-up bumpers and truck beds for hauling wheat from the fields in the 60's. He also raced go karts. In the early sixties he started making racing go karts. Called 'em Caper Karts. Also started making mini bikes and named them Caper Cycles. Not at all faint hearted he installed 2 stroke kart motors in them. These were the muscle cars of the mini bike world.
They were made behind Mr. Ed's cafe, where I had breakfast this morning, in a tall tin building. Hunt Mfg. is long gone but the building's still there. On the door of the shop office is a sign that says: "Don't spit on the floor". This mini was made sometime after '63 because it has a taller frame to also accept an upright 4 stroke engine. Properly known as a Caper Cycle Kingfisher. Serial number 1799. This is the most expensive mini I have ever purchasd...$100. I expect to have about $300 or so in it. That will include the plating because I have a set-up in the basement. I'll use "copy cad" on the cad plated items such as nuts, bolts and drum brake parts. Copy Cad is a lot like nickle but is hard to tell from cadmium. Cad is not done any more because it's too toxic. I already have a reproduction sticker for the forks.
This is intended to be a restoration not just a build to get it looking O.K. so it can be enjoyed as a rider. You know, proper engine and color and seat & etc. & etc.. I usually fake a lot of things on my mini bikes but will strongly resist that impulse on this project.
The forks and frame were badly bent. Pictures showing the frame and fork straighening are attached. Forks had to have the main plate flattened in a press. The fork tubes were repaired by heating and brute force. The engine plate had to be removed to allow the frame to be "loose" enough to be tweeked back into shape. One pic shows a layout on the work bench being used to ensure that the frame and forks were returned to original positions. Both wheels will now be vertical and the forks centered so the bike will track correctly.
Tomorrow the rear brake drum/sprocket assembly will ne overhauled.
