One of the guys from church was cleaning out his basement and asked if I wanted an old 5hp Briggs. He has had in down there for over twenty years and thought it might run! I tore it apart this morning and things didn't turn out so well. Before I even got started there is a crack in the side of the block where the rod had made contact! After I got the side cover off, there was in fact contact between the rod and block. Someone had replaced the rod, and didn't torque the bolts or secure them. The crank got so hot it blued the journal....
Now the good news... the carb is in great shape as well as the tank. The pull start is the cast aluminum! The head is perfect. Between this and another $10 score a few months ago, (also a 1975) I'll be putting together a 1975 Briggs 5hp! The other block is magneto and was missing the carb, cooling tins and the like.
One question for the OldMiniBikes sages; in the second image there is an arrow pointing at a hole. Is this part of some kind of mounting? The parts diagram has it filled with a 10/32 X 3/8 inch hex head screw.
Many thanks in advance, DAN
